Knowledge Base Article
Error (209014): CONF_DONE pin failed to go high in device 1.
Description
You may get this error message in the Quartus® Prime software if you attempt to program an encrypted .pof into a MAX 10 device multiple times after the Encrypted Key Programming (.ekp) file has been programmed.
This is because you can only program the encrypted .pof file into a MAX® 10 device once after the .ekp file has been programmed.
Resolution
If you want to program a new encrypted .pof file into the MAX 10 device, you need to fully erase the device first, program the .ekp file and then program the encrypted .pof file.
Updated 19 days ago
Version 2.0
