Knowledge Base Article
Error (19733): The following instances of High Bandwidth Memory (HBM2) periphery IP are not in the root partition. Remove any instances of this IP in a non-root partition.
Description
In Intel® Quartus® Prime Pro Edition Software version 21.4 or earlier you may get this error when trying to place the Traffic Generator logic used in the HBM2 example design in a separate partition for Partial Reconfiguration when using Intel® Stratix® 10 MX devices.
Resolution
This issue is fixed starting from Intel Quartus Prime Pro Edition Software version 22.1
Updated 1 month ago
Version 2.0
