Knowledge Base Article
Error (19104): "S10_fit_error/altera_xcvr_native_s10_etile_191/synth/S10_fit_error_ip_parameters_wbuqy4a.tcl" cannot be found in the Quartus project database files. Please ensure the missing source file is listed as an SDC_ENTITY_FILE or TCL_ENTITY_FILE a
Description
Due to a problem in the Intel® Quartus® Prime software versions 19.1, you may see the below error when selecting “Enable Multiple Dynamic Reconfiguration Profiles” and not selecting “Enable Dynamic Reconfiguration” in the Intel Stratix® 10 E-tile Transceiver Native PHY IP.
Error (19104): "S10_fit_error/altera_xcvr_native_s10_etile_191/synth/S10_fit_error_ip_parameters_wbuqy4a.tcl" cannot be found in the Quartus project database files. Please ensure the missing source file is listed as an SDC_ENTITY_FILE or TCL_ENTITY_FILE assignment in the Quartus Settings File (.qsf).
Resolution
To work around this problem, you should select “Enable Dynamic Reconfiguration” and “Enable Multiple Dynamic Reconfiguration Profiles” in the Intel Stratix 10 E-tile Native PHY IP GUI.
This problem is scheduled to be fixed in a future version of the Intel Quartus Prime software.
Updated 1 month ago
Version 2.0
