Knowledge Base Article
Error (18496): Output is too close to PLL clock input pin
Description
You may see this error message when compiling a design targetting a MAX® 10 device with no pin assignment in the Quartus® Prime software version 16.1.
Resolution
To work around this issue, manually assign the location of the affected pin away from a PLL clock input pin in Assignment Editor.
This issue is fixed in Quartus Prime version 17.0.
Updated 2 months ago
