Knowledge Base Article
Error (175020): Illegal constraint of PLL output counter to the region (X, Y) to (X, Y): no valid locations in region Error (177013): Cannot route from the PLL output counter output to destination dual-regional clock driver
Description
You may experience the below fitter error when compiling a UniPHY-based memory controller in Cyclone® V SoC and Arria® V SoC device. The error occurs because the FPGA device does not have dual-regional clocks in certain portions of the chips.
Error (175020): Illegal constraint of PLL output counter to the region (X, Y) to (X, Y): no valid locations in regionError (177013): Cannot route from the PLL output counter output to destination dual-regional clock driver because the destination is in the wrong region
Resolution
The workaround is to change pll_avl_clk, pll_config_clk, and pll_addr_cmd_clk from dual-regional clock to regional clock in the.QSF file as follows:
set_instance_assignment -name GLOBAL_SIGNAL "DUAL-REGIONAL CLOCK" -to if0|pll0|pll_addr_cmd_clk
set_instance_assignment -name GLOBAL_SIGNAL "DUAL-REGIONAL CLOCK" -to if0|pll0|pll_avl_clk
set_instance_assignment -name GLOBAL_SIGNAL "DUAL-REGIONAL CLOCK" -to if0|pll0|pll_config_clk
To:
set_instance_assignment -name GLOBAL_SIGNAL "REGIONAL CLOCK" -to if0|pll0|pll_addr_cmd_clk
set_instance_assignment -name GLOBAL_SIGNAL "REGIONAL CLOCK" -to if0|pll0|pll_avl_clk
set_instance_assignment -name GLOBAL_SIGNAL "REGIONAL CLOCK" -to if0|pll0|pll_config_clk
Updated 1 month ago
Version 2.0
