Knowledge Base Article
Error (175020): Illegal constraint of pin to the region <location> to <location>: no valid locations in region
Description
You will encounter the following Quartus® II Fitter error with Stratix® V GX devices if you assign signals to transceiver pins without also connecting these pins to a transceiver PHY instance in your design.
Error (175020): Illegal constraint of pin <pin name> to the region <location> to <location>: no valid locations in region
Resolution
Updated 26 days ago
Version 2.0
