Knowledge Base Article
Error (175020): Illegal constraint of pin to the region : no valid locations in region
Description
In Arria® V devices, some differential pairs only have one of the signals in a DQ group.
When a differential pair of this type is used for the memory clock in UniPHY IP, in the Quartus® II software version 11.1 releases, the placement achieves a successful fit. However, in the Quartus II software version 12.0 release, the placement results in the following fitter error message:
Resolution
In the UniPHY IP file  xxx_addr_cmd_pads.v, find the localparam declaration of USE_ADDR_CMD_CPS_FOR_MEM_BK and change it from false to true.
Recompile the project.
The recommendation for optimum timing is to place both pins of the memory clock differential pair in a DQ group, but in future versions of the Quartus II software, a successful fit should also be achieved when only one of the pins is in the DQ group.
Updated 2 months ago
Version 3.0
