Knowledge Base Article
Error (175006): Could not find path between source pin and the global clock driver
Description
You may see this error message in the Intel® Quartus® Prime Software when targetting an Intel® Arria® 10 device and you have connected the Clock Control Block (ALTCLKCTRL) IP inclk port to a dedicated clock input pin which differs from the Pin Mapping in Arria 10 Devices.
Resolution
Ensure that ALTCLKCTRL inclk is connected to the correct dedicated clock input pin as in Pin Mapping in Intel® Arria® 10 Devices.
Updated 2 months ago
Version 2.0
