Knowledge Base Article
Error (175001): Could not place path required to route a signal from PLD core to the I/O pin
Description
You might see this error in the Quartus® II Software versions 13.0 and 13.1 when using Arria® V or Cyclone® V SoCs. This error occurs when you use Hard Processor System (HPS) I/O pins and instantiate an ALTLVDS Intel® FPGA IP in the FPGA design.
This is not a valid error; there are no resource dependencies between the HPS I/O pins and the FPGA I/O pins.
Resolution
Download the following patch to fix this error for the Quartus II software version 13.1:
Updated 4 months ago
Version 4.0No CommentsBe the first to comment
