Knowledge Base Article
Error (170084): Can't route signal "|altdq_dqs2_stratixv:altdq_dqs2_inst|dqs_enable_int" to atom "|altdq_dqs2_stratixv:altdq_dqs2_inst|dqs_ff"
Description
When compiling a Stratix® V DDR3 UniPHY controller design in the Quartus® II software version 11.1 and 11.1SP1, you may get the following error message:
Error (170084): Can't route signal "<hierarchy>|altdq_dqs2_stratixv:altdq_dqs2_inst|dqs_enable_int" to atom "<hierarchy>|altdq_dqs2_stratixv:altdq_dqs2_inst|dqs_ff"
The error occurs when "enable read DQS tracking" is selected in the DDR3 Megawizard.
Resolution
The workaround is to uncheck "enable read DQS tracking" and regenerate the DDR3 UniPHY controller.
This issue is fixed in Quartus II software and IP version 11.1SP2.
Updated 1 month ago
