Knowledge Base Article
Error (169187): Following feature(s) of I/O pin has invalid setting(s) in the configuration scheme ACTIVE_SERIAL when the pin is placed at pin <location>
Description
You might see this error message in the Intel® Quartus® Prime Software if you change the current strength of the ASDO pin from the default value, in a project targeting Cyclone® III or Cyclone® IV devices.
The ASDO pin only supports the default value for current strength.
Resolution
To work around this, remove the following line from the Quartus Settings File (.qsf) for the ASDO pin:
set_instance_assignment -name CURRENT_STRENGTH_NEW <current strength value> -to <pin_name>
Updated 2 months ago
Version 2.0
