Knowledge Base Article
Error (169008): Can't turn on open-drain option for differential I/O pin
Description
The Quartus® II software Fitter will generate this error if a design has floating bidir pins with differential HSTL, SSTL and BLVDS I/O standards.
Resolution
To avoid this Fitter error, connect the floating bidir pins with differential I/O standards to the ALTIOBUF megafunction in differential mode.
Updated 2 months ago
Version 2.0
