Knowledge Base Article
Error (16767): Can't insert required clock buffer at node
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 16.1 Update 2, you might see this fitter error if you try to fit an empty design as a base revision in a partial reconfiguration region.
Resolution
You can avoid this error by adding at least one register in the partial reconfiguration region.
This problem is  scheduled to be fixed in a future Intel Quartus Prime Pro Edition Software version.
Updated 1 month ago
Version 2.0
