Knowledge Base Article
Error (165011): altmemphy pin placement was unsuccessful
Description
When you implement the DDR3 SDRAM Controller with UniPHY in a MAX® 10 device and add pin location assignments to the DQSn pins in the QSF file, you may get the following fitter error.
Error (13130): The assigned location PIN <pin_number> for DQSn pin mem_dqs_n[*] is not a legal location
As DQSn is a pseudo-differential pin of DQS, a pin location assignment for DQSn is not needed. The pin location assignment on the DQS pin is sufficient.
Resolution
To work around this error, remove the pin location assignment for the DQSn pins in the Assignment Editor or the QSF file.
Updated 1 month ago
Version 2.0
