Knowledge Base Article
Error (16058): PLLs that use the x1 clock network and drive the same HSSI channel must be placed in the same transceiver bank
Description
Due to a problem with Intel® Quartus® Prime Standard Edition Software version 17.1, you may observe the above error if you are using Intel® FPGA SDI II IP with dynamic TX PLL switching enabled in Intel® Arria® V devices.
Resolution
There is no workaround for this problem. This problem is fixed starting with Intel® Quartus® Prime Standard Edition Software version 18.0.
Updated 1 month ago
Version 2.0
