Knowledge Base Article
Error (16058): PLLs that use the x1 clock network and drive the same HSSI channel must be placed in the same transceiver bank
Description
Due to a problem with Intel® Quartus® Prime Standard Edition Software version 18.1 or later, you might see this error when using Arria® V devices, even though your TX PLL is located in the same transceiver bank as the transceiver channels.
Resolution
To workaround this problem you can use Intel® Quartus® Prime Standard Edition Software version 18.0 or earlier.
This problem is fixed in the Intel® Quartus® Prime Standard Edition Software versions 23.1.
Updated 2 months ago
