Knowledge Base Article
Error (15065): Clock input port inclk[0] of PLL <PLL instance name> must be driven by a non-inverted input pin or another PLL, optionally through a Clock Control block
Description
In the Quartus® Prime Standard Edition Software, you might see this error when the reference clock input of a phase-locked loop (PLL) is connected to the output of the Internal Oscillator IP in the MAX® 10 FPGA devices.
Resolution
To work around this problem, do not feed the reference clock input of a phase-locked loop (PLL) with the output of the Internal Oscillator IP .
Updated 1 month ago
