Knowledge Base Article
Error (14566): The Fitter cannot place 1 periphery component(s) due to conflicts with existing constraints (1 IO_AUX(s))
Description
Arria®10 Quartus® design that contains multiple EMIF core IP in the same I/O column will face fitter error if EMIF reset pin sharing design requirement is violated.
Quartus fitter compilation will display following error message.
Resolution
To place multiple EMIF IP in the same I/O column, user must ensure that the global reset signals (global_reset_n) for each individual interface all come from the same input pin or signal.
Updated 2 months ago
Version 2.0
