Knowledge Base Article
Error (14566): Could not place 1 periphery component(s) due to conflicts with existing constraints
Description
You may get this error in the Quartus® Prime software for your Arria® V or Cyclone® V based design if you are driving an fPLL and further user logic from the same reference clock pin.
Resolution
To avoid this error insert a Clock Control Block (ALTCLKCTRL) Megafunction between the reference clock pin and both the fPLL and the user logic.
For further information on using this IP, refer to Clock Control Block (ALTCLKCTRL) Megafunction User Guide (PDF)
Updated 1 month ago
