Knowledge Base Article
Error (13657): VHDL expression error at <file name>.vhd: expression has 1 element, but must have 2 elements
Description
Due to a problem in the Quartus® Prime Pro Edition software version 17.1 and earlier, you may see this error when using a reduction operator (for example, OR_REDUCE) on a single-element array.
In VHDL 2008, this should return the value of the element.
Resolution
To work around this problem, do not use reduction operators on single-element arrays.
This problem will be fixed in a future release of the Quartus® Prime Pro Edition software.
Updated 2 months ago
