Knowledge Base Article
Error (12595): Design Assistant information: Design Assistant does not support current family.
Description
Due to a Problem in the Quartus® II software version 13.1 A10, you may see the following error when you compile an Arria® 10 design with Design Assistant enabled.
Resolution
Arria 10 devices do not support Design Assistant during compilation.
To avoid this error, uncheck the Run Design Assistant during Compilation option in the Settings > Design Assistant page.
Future version of the Quartus II software are scheduled to disable the Run Design Assistant during Compilation option for Arria 10 devices.
Updated 2 months ago
