Knowledge Base Article
Error (12006): Node instance "pfl_ii_inst" instantiates undefined entity "pfl_ii".
Description
When you build the BMC project of Intel® Open FPGA Stack (Intel® OFS) for Intel Agilex® FPGA, you might encounter the following errors:
Error (12006): Node instance "pfl_ii_inst" instantiates undefined entity "pfl_ii". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "max10_qsys_inst" instantiates undefined entity "max10_qsys". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Error (12006): Node instance "i2cm" instantiates undefined entity "svid_i2c_master". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Resolution
To work around this problem, you should use the script build.sh to compile the project. The script is provided in the <path to cloned repository>/scripts folder.
Refer to section 7.0 Procedure for Building MAX® 10 BMC Images of Board Management Controller Developer Guide: Intel Open FPGA Stack for Intel Agilex® FPGA FPGA for detailed usage of this script.
Updated 1 month ago
Version 2.0
