Knowledge Base Article
Error (12006): Node instance "altclkctrl_component" instantiates undefined entity "altclkctrl_inst"
Description
This error message might be seen during the Analysis & Synthesis stage when migrating a design containing Serial Flash Loader FPGA IP from Quartus™ Prime Standard Edition Software version 20.1 and earlier to a newer version of the Quartus™ Prime Standard Edition Software. This is because the code changes in the generated Verilog HDL design file (alt_sfl_enhanced.v) of the Serial Flash Loader FPGA IP require the altclkctrl module to be instantiated in the design.
Resolution
To work around this problem, use one of the following steps:
- Upgrade the Serial Flash Loader FPGA IP using the "Upgrade IP Components" feature.
Or
- Instantiate and add the ALTCLKCTRL FPGA IP in the design.
Related Articles
Why does programming a configuration device with Cyclone® IV E EP4CE75 devices fail when a jtag indirect configuration (.jic) file is used?
Updated 1 month ago
