Knowledge Base Article
Error (10482): VHDL error at measure_trigger_time.vhd(75): object "altfp_div" is used but not declared
Description
In the Intel® Quartus® Prime Standard Edition software version 19.1 and later, you may see the error above when you migrate the design that uses ALTFP_DIV IP from version 18.1 and earlier.
Resolution
To avoid this error, use the FP_FUNCTIONS Intel® FPGA IP instead.
Updated 26 days ago
Version 2.0
