Knowledge Base Article
Error (10476): VHDL error at <VHDL wrapper>.vhd(): type of identifier "reconfig_clk"/"reconfig_reset" does not agree with its usage as "std_logic_vector" type
Description
You may see this error if you perform an IP upgrade in Quartus® Prime Standard/Pro Edition Software version 17.0 of an Arria® 10 design that includes a static VHDL wrapper that instantiates the JESD204B IP core with transceiver dynamic reconfiguration interface enabled.
This is due to the port type change in reconfig_clk and reconfig_reset ports from scalar std_logic to array std_logic_vector.
This problem does not affect designs with the Verilog wrapper that instantiates JESD204B IP.
Resolution
To workaround this problem, map the scalar reconfig_clk & reconfig_reset in the VHDL wrapper to the array reconfig_clk(0) and reconfig_reset(0) of the JESD204B IP core.
Example :
Before change :
port map (
reconfig_clk               => reconfig_clk,
reconfig_reset             => reconfig_reset,
reconfig_avmm_address      => reconfig_avmm_address,
reconfig_avmm_read         => reconfig_avmm_read,
reconfig_avmm_readdata     => reconfig_avmm_readdata,
reconfig_avmm_waitrequest  => reconfig_avmm_waitrequest,
reconfig_avmm_write        => reconfig_avmm_write,
reconfig_avmm_writedata    => reconfig_avmm_writedata,
After change :
port map (
reconfig_clk(0)               => reconfig_clk,
reconfig_reset(0)             => reconfig_reset,
This problem is fixed starting with Intel® Quartus® Prime Software version 17.0.1.
Updated 1 month ago
Version 2.0
