Knowledge Base Article
Error (10430): VHDL Primary Unit Declaration error at dspba_library_package.vhd(16): primary unit "dspba_library_package" already exists in library "project name" and Error (10430):
Description
You may receive below error messages if the design consists of FIR II MegaCore® and Floating Point hardware 2 component in Qsys system.
Error (10430): VHDL Primary Unit Declaration error at dspba_library_package.vhd(16): primary unit "dspba_library_package" already exists in library "project name" and Error (10430): VHDL Primary Unit Declaration error at dspba_library.vhd(17): primary unit "dspba_delay" already exists in library "project name"
Resolution
To work around this issue:
1. User can manually delete one of the assignments that contain "dspba_library_package.vhd" and "dspba_library.vhd" in the .qip file that generated by Qsys.
2. Another work around without manual intervention is that:
 a) Move the dspba_library.vhd and dspba_library_package.vhd from the following directory up one level.
 /../ip/altera/altera_nios_custom_instr_floating_point_2/altera_nios_custom_instr_floating_point_2_multi/FPAddSub
 b) Edit the following .tcl file by delete the FPAddsub/ that in front of dspba_library.vhd and dspba_library_package.vhd.
 /../ip/altera/altera_nios_custom_instr_floating_point_2/altera_nios_custom_instr_floating_point_2_multi/fpoint2_multi_qsys_hw.tcl
 Example after modification:
 set vhdl_filelist [list fpoint2_multi.vhd \
                    fpoint2_multi_datapath.vhd \
                    dspba_library_package.vhd \
                    dspba_library.vhd \
                    FPAddSub/FPAddSub.vhd \
                    FPDiv/FPDiv.vhd \
                    FPMult/FPMult.vhd \
                    IntToFloat/IntToFloat.vhd \
                    FloatToInt/FloatToInt.vhd \
                    FPSqrt/FPSqrt_safe_path.vhd \
                    FPSqrt/FPSqrt.vhd ]
 c) After above modification, please regenerate the Qsys and compile the design by using Quartus® II software .
This issue will be fixed in Quartus II software version 15.0.
Updated 2 months ago
Version 2.0
