Knowledge Base Article
Error (10253): Verilog HDL Module Instantiation error at <design>.v(line #): cannot elaborate array of instances because the declaration for the instantiated module has not been analyzed
Description
This error may occur when synthesizing with the Quartus® II software version 6.1 or 7.0, if your module name matches the instance name.
For example, in the following module called tribuf64bit, there is a module instantiation called tribuf8bit:
module tribuf64bit (output [63:0] out,  input [63:0] in, input enable);
   wire [63:0] out, in;
   wire enable;
   //array of eight 8-bit tri-state buffers; each instance is connected
   //to 8-bit part selects of the 64-bit vectors;
   tribuf8bit tribuf8bit[7:0] (out, in, enable);
endmodule
The instance name tribuf8bit is the same as the module name tribuf8bit. To work around this problem, change the name of the instance to something other than the module name. For example, change the instance name as follows:
tribuf8bit inst_tribuf8bit[7:0] (out, in, enable);
This issue is scheduled to be fixed in a future version of the Quartus II software.
Updated 1 month ago
Version 2.0
