Knowledge Base Article
Error (10158): Verilog HDL Module Declaration error at <module_name.sv > (11): port "<interface_name>" is not declared as port
Description
You may see this error during synthesis in Intel® Quartus® Prime Lite Edition and Standard Editions. This error occurs when compiling System Verilog Interfaces and the port list is coded using Verilog-95 syntax.
module module_a(clk, rst, module_a_inf);
    input               clk;       // Core clock
    input               rst;       // rst.
    module_a_to_module_b_interface.module_a     module_a_inf;   // Module A interface
Resolution
This limitation only occurs in Intel® Quartus® Prime Lite Edition and Standard Editions. There are two options to solve this:
  • Compile using Intel® Quartus® Prime Pro Edition
  • Change the interface syntax to:
module module_a(
    input               clk,      // Core clock
    input               rst,       // rst.
    module_a_to_module_b_interface.module_a     module_a_inf  // Module A interface
Updated 1 month ago
Version 2.0
