Knowledge Base Article
Error: # KERNEL: FAILURE: 32-bit argument is too wide for CONV_INTEGER
Description
If you use the VHDL simulation models for DDR1-, DDR2-, or DDR3-based IP cores with the Aldec Riviera-PRO software version 2010.10, during simulation the Aldec Riviera-PRO software might generate an error similar to the following:
# KERNEL: FAILURE: 32-bit argument is too wide for CONV_INTEGER. Use `asim -relax' to allow 32-bit arguments for CONV_INTEGER
Resolution
Use the -relax option with the asim command.
Updated 3 months ago
Version 2.0
