Knowledge Base Article
Error: # KERNEL: FAILURE: 32-bit argument is too wide for CONV_INTEGER
Description
You may see this error if you use the VHDL simulation models for ALTERA_FP_MATRIX_MULT IP cores with the Aldec Riviera-PRO software. In addition you may see Use `asim -relax' to allow 32-bit arguments for CONV_INTEGER.
Resolution
To work around this problem, use the -relax option with the
asim/vsim command...
Updated 2 months ago
