Knowledge Base Article
Error : INFO: Detected MMU in CPU - Only supported by Altera HAL for internal testing.
Description
In Nios® II Software Build Tools, if you create an Eclipse project with MMU project’s sopcinfo file by selecting MicroC/OS-II and altera HAL with MicroC/OS-II Hello World template, you may fail to create the project and see the error below.
SEVERE: HAL-based operating systems do not support a CPU with an MMU.
SEVERE: nios2-bsp-create-settings failed.
nios2-bsp: nios2-bsp-create-settings failed
Resolution
Altera HAL and HAL-based real-time operating systems do not support the MMU. Do not use MicroC/OS-II Hello World template to create Eclipse project for MMU projects.
Updated 1 month ago
