Knowledge Base Article
Error : Device has stopped receiving configuration data
Description
You may see this error message in the Intel® Quartus® Prime Pro Programmer versions 18.1 or later when configuring Intel Stratix® 10 FPGAs with a design where 3V IO is used, but the respective transceiver tile is not powered up.
The full error message is :
Error: Device has stopped receiving configuration data
Error message received from device : Device is in configuration state
Operation failed
Resolution
To avoid this error and to enable 3V IOs in a design targeting any variant of Intel Stratix® 10 FPGAs, power up the VCCR_GXB and VCCH_GXB rails of the respective transceiver tile as per the Intel Stratix 10 Device Family Pin Connection Guidelines.
Updated 3 months ago
