Knowledge Base Article
Error: # ** Error: (vlog-7) Failed to open design unit file "<installation_path>/tennm_hvio_ncrypt.sv" in read mode
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.1, you might get this error when calling the Quartus® EDA Simulation Library Compiler with the '-family all' option.
E.g. quartus_sh --simlib_comp -family all…
Resolution
There are two ways to work around this error:
- Open the file sim_lib_info_pkg.tcl from the installation path 23.1/quartus/common/tcl/packages/sim_lib_info/sim_lib_info_pkg.tcl, and remove all the lines that contain the strings below:
- tennm_hssi_sm
- tennm_hvio
- agilex5
- Specify a particular family name using the -family option instead of specifying -family all.
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 23.4.
Updated 3 months ago
