Knowledge Base Article
Empty Source Address Field in Flow Control Frame
Description
When you disable address insertion on the transmit path and enable flow control in 10GbE MAC designs, the IP core does not insert source address into the generated flow control frame.
This issue affects all 10GbE MAC designs.
Resolution
This issue has no workaround.This issue will be fixed in a future version of the 10-Gbps Ethernet MAC MegaCore function.
Updated 2 months ago
