Knowledge Base Article
Embedded Synchronization Mode Removed from Clocked Video Output II IP Core v15.1
Description
Due to functionality issues, the embedded synchronization mode option was removed from version 15.1 of the Clocked Video Output II IP core. However, if you migrating from an existing design, you can still set this mode.
Resolution
There is no workaround for this issue.
This issue is fixed in version 16.0 of the Clocked Video Output II IP core.
Updated 18 days ago
Version 2.0
