Knowledge Base Article
elf2flash File Size Limit
Description
The elf2flash utility supports .elf files
up to approximately 24 MBytes in size. The elf2flash utility
might fail on files larger than 24 MBytes, with the error message java.lang.OutOfMemoryError.
Resolution
Lower the number of symbols in your .elf file by turning off debug symbols.
Alternatively, specify less initialized data in the application.
Updated 3 months ago
