Knowledge Base Article
EIC-Based Nios II System Crashes With NicheStack
Description
When you attempt to run software based on the NicheStack TCP/IP Stack - Nios II Edition on a hardware design incorporating an external interrupt controller such as the VIC, the Nios II system crashes during initialization, with unpredictable results.
Resolution
There is no workaround.
Updated 1 month ago
