Knowledge Base Article
Efficiency Monitor Latency Values Are Incorrect for DDR2 and DDR3 SDRAM Controller with UniPHY and RLDRAM II Controller with UniPHY
Description
The Efficiency Monitor and Protocol Checker counts read latencies incorrectly for Avalon burst counts equal to 1; this causes the EMIF Toolkit to report incorrect values for minimum and maximum read latencies.This issue occurs if you measure efficiency with the example design driver; however, if you use your own custom driver that does not issue an Avalon burst count size equal to 1, the error will not occur.
Resolution
The workaround for this issue is to use a custom driver that does not issue an Avalon burst count equal to 1.
Updated 2 months ago
