Knowledge Base Article
E: Unable to locate package doc2unix
Description
Due to a typographical error in the Intel® FPGA Software Installation and Licensing documentation, when you are following the instruction for Installing Windows Subsystem for Linux* (WSL) on Windows distro packages, you may see this error:
E: Unable to locate package doc2unix.
Resolution
In order to successfully install the distribution packages, you must execute this command line, instead.
a. sudo apt install wsl
b. sudo apt install dos2unix
c. sudo apt install make
Updated 2 months ago
Version 2.0
