Knowledge Base Article
DSP Builder Generates Illegal VHDL
Description
DSP Builder generates illegal VHDL if you turn on Expose bus ports option on a FIR block that uses write-only coefficients.
The generated VHDL entity declaration for the FIR block has bus input ports but no bus output ports; the corresponding VHDL component declaration has both bus input and bus output ports.The Simulink block also (incorrectly) shows bus output ports.
Resolution
To work around this problem, use read/write coefficients on the FIR block.
This problem is fixed in DSP Builder v12.1.
Updated 2 months ago
Version 2.0
