Knowledge Base Article
DQS# Enable Option Must be Enabled for LPDDR2 Interfaces
Description
This problem affects LPDDR2 products.
The LPDDR2 interface supports only differential DQS signals. The DQS# Enable option on the Memory Parameters tab in the parameter editor must be enabled.
Resolution
The workaround for this issue is to ensure that you always enable the DQS# Enable option for LPDDR2 interfaces.
This issue will be fixed in a future version.
Updated 2 months ago
Version 2.0
