Knowledge Base Article
Does the UniPHY controller write back the data to memory when a double-bit error happens with enable ECC option turned ON?
Description
Yes, actually controller is writing back the same read data to the memory, although the double-bit error is uncorrectable.
Resolution
There is no workaround to fix this problem.
Updated 2 months ago
