Knowledge Base Article
Does the SDI Audio MegaCore support OpenCore Plus Hardware Evaluation Feature?
Description
The SDI Audio MegaCore® does not support the OpenCore Plus Hardware Evaluation Feature. Thus, you will receive the following error message when a valid license of SDI audio MegaCore is not available.
Warning (115003): Can't generate programming files for your current project because you do not have a valid license for the following IP core or cores.
Resolution
This issue will be fixed in a future version of the SDI Audio MegaCore.Updated 3 months ago
