Knowledge Base Article
Does the Quartus II software version 11.1 SP2 include all the fixes from the Quartus II software version 11.1 SP1 device patch 1.dp11?
Description
No, the Quartus® II software version 11.1 SP2 does not include all the fixes for Stratix® V and Arria® V devices from the Quartus II software version 11.1 SP1 device patch 1.dp11. Fixes for the following issues in the readme for device patch 1.dp11 are not included:
Issue 18 (31645)
Quartus II triggers the following error when openning Chip Planner for
Stratix V designs with DQS FF:
Fatal Error: Access Violation at 0X000000001CED28C5
Issue 23 (32785)
Alt_syncram is missing some timing paths for Stratix V M20K ECC modes.
Issue 26 (33894)
Internal Error: Sub-system: ASMCC,
File: /quartus/comp/asmcc/asmcc_bitfield.cpp, Line: 882
Assembler bitfield error: Found conflicting assignments for CRAM address; address = 4935431
Issue 27 (34197)
Internal Error: Sub-system: ASMIO,
File: /quartus/comp/asmio/asmio_oct.cpp, Line: 714
!is_differential
Issue 28 (34212)
Address decoder in Stratix V soft XAUI had incorrect connection,
making registers in address range 0x40 -0x7F inaccessible.Resolution
For all the current fixes for Stratix V and Arria V devices, install the Quartus II software version 11.1 SP2 and install the latest device patch from the related solution below.Related Articles
Updated 2 months ago
