Knowledge Base Article
Does the FFT MegaCore implement the Global Clock Enable feature for the Floating Point Variable Streaming?
Description
The FFT MegaCore® does not implement the Global Clock Enable feature for the Floating Point variable streaming.   The following error messages will appear when both “Global Clock Enable” and  “Floating Point” are selected:
MegaCore Function Generation Error
IP Functional Simulation Model Creation Failed. The following error was returned:
Error: Quartus II 32-bit Analysis & Synthesis was unsuccessful, 1 error, 1 warning
  • This error message is given when generating the FFT MegaCore Functional Simulation Model
Error (12002): Port "clk_ena" does not exist in macrofunction "apn_fftfp_top_fft_130_inst"
  • This error message is given when the Quartus® II software performs Analysis & Synthesis
Resolution
This issue will be fixed in a future version of the Quartus II software.
Updated 2 months ago
Version 2.0
