Knowledge Base Article
Does the DisplayPort IP support audio data channel when the secondary data channel mode is enabled?
Description
Yes, the DisplayPort IP supports audio data channels when the secondary data channel mode is enabled.
To use the DisplayPort IP parameters support audio data channel option, you must also turn on support for the secondary data channel.
Resolution
This information will be included in a future DisplayPort IP User Guide release.
Updated 3 months ago
Version 3.0
