Knowledge Base Article
Does the design security feature or the compression feature affect the compatibility of programming files with EPCQ-A serial configuration device?
Description
No, irrespective of whether the design security (AES encryption) feature or/and the compression feature are used, the programming file compatibility with EPCQ-A serial configuration devices is not affected.
You can find the programming file compatibility with EPCQ-A serial configuration device in the following application note.
Updated 3 months ago
