Knowledge Base Article
Does the Arria II GX PCIe example design take into account the pll_locked errata issue?
Description
Yes, when using the altpcie_serdes_rs.v file for Arria® II GX device, the code is designed to hold off the tx_digitalreset assertion similar to the pll_locked_soft_logic available from the Arria II GX Errata. No additional user logic is needed to account for this issue.
For more information related to this erratum, refer to the "Transmitter PLL Lock (pll_locked) Status Signal" section of the Arria II GX Errata Sheet.
Arria II GX Errata Sheet (PDF)
Resolution
Updated 3 months ago
