Knowledge Base Article
Does Stratix V QDRII/ SDRAM Controller at full rate have timing closure issue?
Description
Yes, you might experience out of box timing violations with Stratix® V QDRII/ at full rate. This issue will be fixed in a future Quartus® II software and IP version.
Resolution
To workaround this issue, in the SDC file locate these lines:
                if {} {
                                set_clock_uncertainty -to [get_clocks _*] -add -hold 0.200
                                set_clock_uncertainty -to [get_clocks _*] -add -hold 0.100
                                set_clock_uncertainty -to [get_clocks _*] -add -hold 0.160
and change them to
                if {} {
                                set_clock_uncertainty -to [get_clocks _*] -add -hold 0.400
                                set_clock_uncertainty -to [get_clocks _*] -add -hold 0.150
                                set_clock_uncertainty -to [get_clocks _*] -add -hold 0.225
                                set_clock_uncertainty -to [get_clocks _*] -add -setup 0.200
Updated 2 months ago
Version 2.0
