Knowledge Base Article
Does Quartus II synthesis support multi-level hierarchy configurations in VHDL?
Description
Multi-level hierarchy configurations in VHDL are currently not supported for the Quartus® II Integrated Synthesis. An example of a multi-level hierarchy configuartion is shown below:
--top level
ENTITY top IS
CONFIGURATION top_conf OF top IS
    USE ENTITY work.submodule(first_sub_arch);
    USE ENTITY work.submodule(second_sub_arch);
--second level
ENTITY submodule
ARCHITECTURE behavioral OF submodule IS
BEGIN
    first_sub_arch_instance : lowestmodule ...
    second_sub_arch_instance : lowestmodule ...
END behavioral
--third level
ENTITY lowestmodule IS
ARCHITECTURE first_sub_arch OF lowestmodule IS
ARCHITECTURE second_sub_arch OF lowestmodule IS
Resolution
To work around this issue, define a separate configuration for each of the submodules. An example of this workaround is shown below.
--top VHDL
ENTITY top IS
    USE CONFIGURATION work.submodule(first_submodule);
    USE CONFIGURATION work.submodule(second_submodule);
--second level
ENTITY submodule
BEGIN
    first_submodule_instance : lowestmodule ...
    second_submodule_instance : lowestmodule ...
END behavioral
CONFIGURATION first_config OF submodule IS
CONFIGURATIOIN second_config OF submodule IS
--third level
This syntax is scheduled to be supported in a future release of the Quartus II software.
Updated 1 month ago
Version 2.0
